Another window question
Just a quick question about replacing the front window glass runs. I just replaced the rear window runs which went very smoothly. I didn't have to take the door apart to do the rear glass runs but was unsure about the fronts. I have read other posts about the fronts but they involved other repairs that required the door being taken apart. Do I need to take the door apart to replace the front window glass runs or can I just pull the old ones out and push the news one in like the rears.
Thanks
I say go for it; i.e., try just pulling the runs like you did for the rear. Pretty sure this is *not* how the FSM says to do it, but that's because the directions are for total door disassembly, with removing the runs as part of the process.
Even if it doesn't work, I can't think of how you'd hurt anything, and then you could just do it by going into the door after all.
If you try it, please let us know; I've been curious about this myself.
Curtis
Oh, and don't blame me if something does break! ;)
Just pulled the drivers side glass run out and pushed the new one down in. It took about 10 minutes but worked. I used a little liquid soap to lube the run a little (there was no need for this on the rear runs). The front portion of the run went in in about a minute. The rear portion of the run was a little tougher. After lubing the outside of the run I was able to run the window up a little and then lower it while pushing on the run and that made it slide down the channel a lot easier. So in short there was no need to remove the door panel to insert the new runs. The little bit of liquid soap made a big difference in ease of installation.
If your windows rattled when they were part way down did this cure the rattle?
All 4 windows are faster now. The passenger window is still slower than the rest of the windows so it is going to require a little more investigation. But it is at least going up and down now. Before the new runs were installed the passenger window would get stuck about half way down every time it was used (should have kept the child locks on to keep my friends from rolling it down).
I never had any rattle in any of the windows so I cant help you there.
