Another window prob
So my rear passenger window stopped workin but I'm hearing the motor work. I opened it today and found this pics below. The green plastic wheels comes off that wheel track when I roll it all the way down . Is there a stopper kind of thing that I'm missing on that edge so wheels won't come out the tracks? Thanks
I've found that the green wheel goes off the track because something isn't tight. Tighten everything that is visible on the door panel first inside the door, then outside. Of course, all of this is after you have reseated the green wheel. Also, try lubricating the wheel and the guide so it moves freely and smoothly. Lastly, look to make sure the window is in the track correctly, specifically the furthest point back of the window, just below where the window disappears into the door. Make sure it rides the track all the way up and down without becoming unseated. Hope that helps.
The actuator arm moves in a pendulum motion and when it's at the apex, the green wheel wheel (in your case) sets just inside the track. If not, something could be loose as musthave stated. The other scenario is that the entire track that mounts to the bottom of your window has shifted. The bracket in your pic shows a rubber channel that holds the glass, does it look as though the bracket and channel or the channel and window have shifted? If so, lubricate with something like WD-40 (you DON'T want permanent lubrication here) and shift it back. While you're in there, use some lithium grease on the actuator arm and roller.
Just had the same thing happen to me.
Pop the wheel back on the track some how and pull the track towards the rear of the car. Also use some dry silicon lube in the wheel and track to help the window move better.
Ok thanks I got it lubed and workin for now but it's not 100% it can come off anytime when those runs get stiff again. So a new runs will be on the to do list . Thanks everyone .
My track was moving on the window when it got wet or cold. I used some FIPG on it and it stopped moving, and stopped coming off the track. It's been 6 months without issues.
The window runs is a common replace item due to age. Silicone spray will work temporary, permanent solution will be new runs. I do carry the window runs set with great discount if you need them:
https://forum.ih8mud.com/threads/genuine-toyota-91-97-series-window-runs-set.822322/
Just lubed it and put it back . I played it up an down and I noticed that it ran smoother after lubing the runs but it's only a matter of time when that runs gets dry and stiff again. I ran it before I lubed it and noticed the resistance on the runs and when that green wheel/ slider is at the end part of the track it will come off the track due to resistance or stickiness.
Just had this happen as well and found that the actual track that the green wheel rides in had shifted forward on the glass about an inch or so (as mentioned) allowing the wheel to disengage from the track at about the halfway down position. The fix was pulling the track back toward the rear of the glass. There was evidence on the glass of where it was originally because the rubber protecting the glass was sticking out from the metal track. I put a little thin glue along the track to rubber contact area in hopes it would wick in and stop it from moving in the future bit not sure what will keep it in place long term.
