Another Turboglide Install
Parts Unknown
First , a quick thanks to all who helped answer my guestions and all those who came before me. You were truly a huge help!:cheers:
The turbo showed up on a rainy day.
Comes pretty much complete.
I asked for some suggestions on mounting the gauges and got many ideas. I decided to fab a simple bracket and install it using only existing bolt and screw holes.
Now the fun begins time to start disasembly :). It's probably dumb luck on my part but adding a turbo helped me discover the ex manafold gasket was cooking through.
I was worried about breaking bolts but all came out easily. I figured it would be easier to detach the turbo from the new manafold. I was right on that one. Together it's a pretty heavy buggar and a tight spot to get it in.
In the meantime my booster gave up and then the mastercylinder about 3 weeks after the booster. So, while my rig was down I figured a good time to fix this too.
You guys aren't kidding when u talk about expence. But it is fun completing projects no matter how small. The booster was for LHD so I had to shorten the rod and install it upside down which meant rearranging the vacuum tube.
Looking awesome!!!
But how about a pic of the whole car, please?
Oops the pic
That is a cool idea, i should have though about that! But the gauge are deep, will they touch the air vent?
Before I bolt up the turbo, it seemed like a good time to tap for the pyrometer.
I already had a bolt there, maybe because i ask them where i will mount the pyro, so they weld a nut there.
