Another squeaking noise thread ... stumped.
Arizona / Mexico
Website
www.youtube.com
06 LC and at low speed, I can hear a rather audible squeaking noise that seems to be rotational. It's in sync with the rotational velocity of the wheels ... Or front axle shafts? I don't think it is the breaks. I apply the breaks and the noise is in affected. It sounds like something is dry? I don't see any tears in the boots ... Could it be bearings? What should I take a grease gun to first.
Cheers
Its the emergency brake probably stuck or seized.
Yesterday, I pulled the e brake really just out of curiosity (hadn't used it in a long time) and it was very loose. I was thinking I'll have to take the rear wheels off and get my flathead screwdriver to try to get in there and adjust the tension ... I think you might be right. It might be stuck ... and very slightly engaged?
Soooooo ... I just pulled the wheel and adjust the passenger side e brake. Noise gone! It was sticking in there and there was not enough tension .... ALL BETTER
And another interesting twist. While yes the e brake now does not make noise, the front driver wheel was the ACTUAL culprit. So problem persists. It's rotational, it's coming from what seems to be where the CV axle connects with the wheel. I thought maybe mud was in there, so I washed it and the noise subsided but when it dried it came back. So seems something needs to be greased up. Will research ...
Did you make any progress with this? I have the same problem. Thought it was the front wheel bearings, which I changed no difference. Could you get to the CV axle to grease it up?
Here is the UPDATE: I ordered new inner and outer bearings, races, seals, flange gasket, spindle bearing, and gasket and that gasket that goes between the passenger side brake shield and the dust seal ring that goes over the ABS sensor. This is past the steering knuckle inboard. I also got the brass bushing, the wheel seals inner and outer ... new lock and claw washer and a set of those little c clamps from 2.2mm to 2.8mm etc... While I was waiting for the parts to come in I took the truck out to Glamis Sand Dunes over Thanksgiving and ran her pretty hard in the sand.
When I returned to AZ ... there were no more noises. Nothing ... not even a squeak. Tried turning the front wheels lock to lock ... nothing. Against better judgment (I have zero) I put the truck on floor jacks, and dropped her in D and let the wheels turn, and climbed under the truck to see if I could hear anything ... zilch. All my parts came in ... I have this huge case of grease and a new grease gun and axle puller tool just sitting in my garage. So I think I am going to order an Axle, Flange, and some bushings and just have a whole set ready to swap in if she starts acting up again. I jacked the truck up, and there is no play, no noises ... nothing. But whatever it was ... is gone or completely broken. I have e lockers coming for front and rear and a low range T case gear and 4.88's I will put in the diffs ... so when the truck is down I will probably just rebuild the front end stuff ...
