The speedometer, odometer, and cruise control suddenly stopped working on my 1994 and would just stay at zero. Checked VSS1 and that was working just fine (based on the FSM, #1 Speed Sensor Tests OK - Pics , speedometer & odometer not working , and No speedometer....Speed Sensors?? ), then tried to trace the wires to connector that is described as being near the starter or transmission, but I couldn't find that.
Found these links ( and Intermittent speedometer ) and figured I'd take a look at the speedometer board since some of the bulbs are busted in my instrument cluster anyway! Off came the dash and cluster, removed the clear front of the cluster and 4 screws holding in the speedometer.
This looks busted across the top:
Took off some of the green coating (it was so bad I could just rub it off) to to find this:
Which to me looks like a total break in the trace in the yellow outlined area. So, where did I put that soldering iron? (answer: with the RC car parts)
Replace the bulbs and everything went back in the dash. BTW, the LED thread says the big bulbs are 194 and small bulbs are 74, but I could not get Sylvania 74s to fit in the twist lock base. Sylvania 2721 did the trick. Does anyone have the part number for the little brown twist-lock bulbs that light up the PRND2L in the dash?
I still had the VSS out, so I spun the VSS using a little drill in low speed and SUCCESS! Working speedometer. Took it out for a ride and cruise control works again, too. We'll see how long it lasts for, but I'm also hoping this explains why my cruise control would cancel whenever going up steep-ish grades.
Good luck to anyone else with speedo issues! This is my first real "fix" post, so hope this was helpful, and thanks to everyone here over the years for all the knowledge.
