No he's had it a year it's his beach and camping rig but is also getting married and his second car has to go to buy a ring. I auto checked it and nothing bad came back except five owners
Is there any rust from being in the middle of the ocean? The 3FE engine is a very solid engine that has no known issues other than being under powered. It has a cast iron head and is known to go for a very long time. $3500 seems like a desent deal.
So I picked her up today here's to a hopefully long journey together. Thanks everyone for your input I'm sure it won't be the last time I come here for help.
The front knuckle balls look very dry. Need to check the Moly grease levels in that ball. (Small square-head plug on top of knuckle housing.) Pull plug, use a long zip tie to insert to see how much GREASE is in there (NOT oil) The balls look very dry as if there is little to no grease. Should be 3/4 + full of Moly grease (Valvoline Palladium is what I use). If empty, it will take 1-1/2 tubes per side.
Looks like a few leaks on the front of the engine. Probably Oil Pump seal, front main seal, power steering hoses.
Check ALL your fluid levels and look at the fluid quality. Is the engine oil black or is it honey colored? Check the oil in the differentials if the front one is black and goopy, you have a front axle rebuild coming your way. The rear diff oil should be honey colored. Check all and make sure they are topped off.
Check the belt condition. The belts SHOULD be smooth back belts to indicate Toyota belts. The Toyota belts will be quieter and a bit stronger than aftermarket. Make sure your idler pulley is in good shape and spins quietly.
