Another RTH: Rotor Dist. Position
Vermont
I'm replacing my dist and the rotor position is at 6 o'clock, obviously I need to change that to between 11 and 12. How do change its position?
good idea...
i learned about the crankshaft pulley method, was going to remove the fan and when i went to remove the bolts that go into the body the whole contraption moved so i was able to get the timing notch at 0 and the rotor position moved to 11-12 without much effort. i hope that does it.
