- Joined
- Mar 20, 2015
- Threads
- 19
- Messages
- 87
My sons 99 LX had the rear drive shaft ujoint go completely out. It had more than a wobble and prob wasn't safe to drive. I went ahead and had a new shop install front and rear drive shafts since they appeared to be stock.
After picking it up it still had a vibration once you got over 50 and there were no other vibrations prior but it was still better than before.
Fast forward a couple of months and we just had a new a/c compressor put in by my old shop and when looking at the bearings one was completely shot. So we did new bearings and cv axles as the left front was coming apart and I figured that was the roar and vibration. It only happens at 50 above and in town there are no speeds over 45 so it drives fine until 50 and up. Current shop did not drive on interstate so it drove great for them.
My question is could the driveshafts:
1. Been installed wrong
2. Not have been straight or balanced to begin with
3. Would not enough grease attribute to this
And finally what test can I do to maybe eliminate something. Going back to shop when I pick up my 05 highlander that needed an a/c compressor too.
The roar at highway speeds is load and side mirrors vibrate so bad you can see in them. Oh and not shake in Steering wheel so tires appear to be balanced.
Thanks in advance!
Thanks in advance!
