Another Question About Wheels
Cloverdale B.C. Canada
Website
www.instagram.com
I Have A Set Of American Racing Aluminum Wheels ( Gambler ) Discontinued Wheel . With All This Talk Of Backspacing . I Was Curious About My Wheel ,so I E-mailed Them . And Got The Specs For My Wheel . They Said 15x10 With Approx 4 Inch Back Spacing .does That Sound Right . I Know They Are 15x10 . But 4 Inch Back Spacing .
Does 4 Inch Back Spacing Fit The Cruiser . 78 Fj40 Disc Front End . The Rim Fits Real Close To The Tre. But Does Not Rub . Any Info Would Be Great . I Did Have To Grind The Calipers A Bit . But Not Much .
Jake .
I Guess So . But All The Info Says Use 3.5 . Back Spacing I Thought Maybe They Sent Me The Wrong Info . I Guess 4 Inch Back Spacing Does Fit ! Then Why All The Talk About 3.5 ? Will 4x4 Lab's Arms Still Work With This Wheel ? Guess I Will Have To Talk To Them . LOVE ANSWERING MY OWN QUESTIONS
JAKE
Backspacing of 3.5" is pretty much the standard. There have been others that have run a 4" BS wheel without issue. I would think that it is a wheel specific issue, as you have found.
Good luck!
-Steve
By the way
Luke at 4x4 Labs is great to work with.
Backspacing and caliper clearance not really related. You need the correct backspacing to clear the tie rod ends. What matters with the caliper is the shape of the center section.
I thought that 3.5 inch backspacing was close to stock, 3.75 was acceptable in some cases, and 4.0 was useally to much.
I had 3.5 inch back spacing on my wheels and had the grind the calipers. But I had plenty of room on the tie rod ends.
There are lots of threads on this.
Jared
I KNOW THERE IS LOTS OF THREADS ON THIS BUT NONE OF THEM MENTIONED 4 INCH BACK SPACING SO I ASKED THE QUESTION . AMERICAN RACING SAID I HAD 4 INCH .SO I WAS LOOKING FOR INFO ON 4 INCH BACK SPACING . BUT IN MY CASE IT WORKS . I THOUGHT MY RIMS HAD 3.75 INCH BACK SPACING .JUST LOOKING FOR INFO ON THE 4 INCH BACK SPACING WHETHER IT FIT OR NOT .I GUESS IT DOES
jAKE
Another Question About Wheels.
Hi All:
Did you say 15X10 inch rims!?! How wide a tire do you plan on fitting on that wheel!?!
A 14.5 inch width tire would probably be a good starting place! ;-)
A ten inch wise rim is waaaay too wide for a 12.5 inch wide tire, you'll loose the bead seat while aired-down, collect all kinds of twigs, pebbles, etc. inside the rim seating area.
Regards,
Alan
i already have these wheels and i am running 38.5 x 14.5 swampers . should fit the 15x10 fine . actually i have been running this tire and wheel combo for about 6 yrs . i just didn't know what my actual back spacing was and when i heard 4 inches i got curious
Jake
