Another PS power seat issue
Birmingham, AL
First off, thanks to Mud for the help with the little white screw fix and it works great. But, it only works when the rear two brackets of the seat are not tightened down. Once the seat is tightened down, the power seat function will not work going towards the rear. Then, once you loosen up the two bolts it works better and when the seat is not bolted in at all, it works great.
Any thoughts?
the lead screws are probably not in sync and binding when you bolt down the chair. Pull the chair from the truck and turn it upside down. You'll see the lead screws on both sides and the following nut that bolts to the side of the seat rails. Measure the distance of the front of those nuts to the edge of the gear box. The distance should be the same. If it isn't then you'll need to sync the two gear boxes so the distance is the same.
Thanks for the info. The lead screws were not in sync and now they are.
It works great so far. Lets keep those seats a movin!
Thanks again.
