Another power window thread...Yeah I know
Boise, ID
I had the same problem with the driver's window as most of you. I cleaned the switch contacts and checked the general condition of the wires. That got me working about half the time. I replaced the window run, and the window goes up and down at a decent speed. All is well right? Wrong. I still have an intermittent problem. I believe it's the overload circuit kicking in. Sometimes the window just stops, and won't work for a few seconds. Could be 30 seconds, could be a couple minutes. Eventually it will work though, and when it does it goes up and down as though nothing is wrong. Anybody have a solution that is specific to this issue? I haven't pulled my regulator out and checked it yet, but I have greased all the slides while it is in the door. It really doesn't seem to resist much if any. I should add, the window went up and down easily and smooth when the window run was removed, so the new one does seem to add a bit of drag.
Well I decided to take apart my regulator and see what was causing the problem. Low and behold, it's the motor. The window run probably helped, but the reason the window would stop was that the main gear on the motor that directly turns the regulator has enough side to side movement to stop itself on the case. Here are the pics and captions.
Parts disassembled on my bench.
As you may be able to tell, this is a pretty simple mechanism. The problem mine has/had is the plastic "bearing" the metal gear rides in had become out of round allowing the gear to contact the case. Hard to see in cellphone pic below
Other then drilling it out to a larger hole and finding some sort of spacer to ride inside the right diameter to fit tight and snuggle support the gear shaft, there isn't much you can do. I also noticed that the keeper was broken, and had probably been what allowed the gear to wobble in the first place. I found a suitable replacement in my tool box.
I cleaned and regreased the case and got ready to reinstall the components.
Here you can see the plastic gear and hub reinstalled. The hub is really what holds the gear in and straight.
After I reinstalled the gear with the new keeper I decided to add a little support for the gear shaft. The cover has a pin that sits in the center of the end of the gear shaft to support it as well. You can see the little nipple below.
I put the cover on my vise with the nipple facing down and gave it a few tap with a hammer. This put a little pressure on the gear shaft helping to hold it.
I reassembled the case and started to reinstall the motor to the regulator. I noticed that the lift assist spring has room to be stretched a little further, so I moved the end to the next metal tab on the regulator. You can see the spring below in it's stock location. I simply moved it to the tap on the regulator on the opposite side of the mount. This made it nearly double the assistant lift.
I then reinstalled everything like everyone has done a bunch of times. The result? Well so far it works flawlessly. Keep you fingers crossed for me. If it fails again I will make a new bearing insert as implied above.
my when tem,under 32* only go down 1/2 way:bang:
For the less mechincally inclined, can we just get a replacement regulator?
My power window performance is directly linked to outside air temperture. The colder it is the slooower moves.
Well, the regulator was fine, but you cold just replace the motor.
UPDATE
I was able to get the motor to fail the same as before, so out it came for a sleeve in the bearing area of the housing. I used plastic water line 3/8 x 1/2".
I had to drill the interior to 13/32" to get a snug but not to snug fit on the gear shaft.
Then I had to drill the housing to 1/2". I did this by stepping up slowly with bits from the first bit just barely dragging.
Then I installed my sleeve and reassembled as before.
A GREAT TIP!
I found that after I installed the window was slightly slower then before on the up. The reason is, if the regulator is not adjusted right, the window is pushed into the window run and drags. There is only one adjustable bolt with a slotted hole when you pull the door panel. This bolt adjusts the angle the window tips as it goes up. By adjusting this so that the window pitches every so slightly AWAY from the window run the window doesn't drag going up. For a test I adjusted the passenger side this way. Before it was showing all the signs of needing a window run replaced as well. After the adjustment it acted nearly as good as the driver side with the new one. It's worth a try!
UPDATE
A GREAT TIP!
Can you show us a picture of the adjustable regulator bolt? I believe that could solve the problem with my front windows because they drag and slow to a crawl the last 6 inches and cleaning/greasing the regulator and new window runs have not produced any huge improvement as others have seen. I, as many others might have the problem of the motor bearing egging out too. It would be nice to get a group buy on some brand new motors! I want to get theses windows back to new and so I can do Landtank's auto window up mod. https://forum.ih8mud.com/80-series-tech/15277-auto-up-window-mod.html plus its too cold and noisy with the door panel off!
My panels are all back on now, but I can describe it. The motor has 4 10mm size heads holding it on the hinge side of the door in a diamond shape. The only other two 10mm heads hold one of the slides for the regulator. One of those bolts is in a standard round hole and is not adjustable. The one closest to the latch side has a slotted hole and can be slid up and down in the slot once loosened. The higher you set it, the further AWAY from the window run the window goes. I would caution against adjusting it so that the window is more then a few mm away, but you can play with it before putting the door back together. I put the window up and down several times until I had it just far enough away not to drag. There's really not that much adjustment, so it doesn't take long to find the right spot. It may not be a fix for everyone, bit I think it's one of the problems we have. As dirt builds up in the run, a little adjsutment may very well help the dragging on the way up as the runs age.
It has 165000 on it, and I see no indication the motor isn't original.
Anyone have a picture of this bolt? I couldn't find it last time I was in there.
When you say adjust slightly away from the window run, do you mean towards the front of the truck?
Thanks
Excellent mud post, superb and what does one do to correct a driver side window that screeches or scrapes sometimes? I'm in Florida and the least bit of cold, screeches but then quiet once the temp rebounds. Thoughts?
Sand/dirt stuck in the (hardened from age) rubber window runs, the fix is to replace the runs. Do a search for slow+windows in the 80 forum.
