Another Power Steering Question
SE Mo
Ok, before asking this, I HAVE gone thru the search feature but didn't find what I'm looking for. My question is- I have a MAF shackle reversal on the front of my truck, and due to a sloppy/loose stock steering box, am wanting to go to a Saginaw p/s setup. I'm wondering if the mounting plate for the gearbox ( mainly the lowwer bolts for the steering box ) is going to be a problem. Have allready replaced bearings, tie rod ends, etc. What say the experts? Thanks, Al
The plate for the Saginaw box goes on the inside of the drivers side frame rail. Unless your shackle revesal is different than mine it should not be a problem. The shackle reversal plate is on the outside of the frame on mine (MAF).
Nocents
Ok, I see what your saying. I guess my concern is, the spring hanger part that angles back under the frame interfering with the lowwer bolts on the steering box/mounting plate. Does this make any sense? Just visulizing it has me wondering. Thanks nocents. Al
Alz Toy, I just got done tacking one of Faultline's plates on Friday. The forward lower bolt did not quite clear the stock shackle hanger. I cut a half circle the size of a quarter out of the inboard side of the hanger to properly clearance for the bolt.
I am not familiar with the MAF brackets, but if it is true that it mounts with an outboard bracket, I would think that the rest of the equation would be as simple as notching the PS plate for any overlap on the inside.
Don't know if that helps.
Another thought. I had to turn the upper shackle bolt around [bolt side in instead of nut side in] because the steering box comes pretty close to the frame. Now I am wondering if the shackle reversal might have the same bolt clearance issues. This is prolly something you should be getting an answer on as well. Maybe somebody has a pic of the area in question they will share. :idea:
