Another OME Suspension question...
New Mexico/Colorado
I know, search first!! I did, and the opinions were varied on what type of OME setup to use (depends on how you are going to use vehicle). First off, let me say i have already pulled the trigger and am i second guessing my selection :bang: I ordered the Heavy Kit with J springs and L shocks all around; i want the ability to run 35's in the future (running stock 275's right now...) as well as the ability to accomodate more weight as i add it. I just added ARB and will add winch and possibly 2nd battery in the next year or so. In the rear, i am stock now but will install 1/2 drawer system with @100 lbs of gear daily (more like 250 on road trips). Rear bumper is a possibility, but i am looking for a more economical solution (under $1G) for swing away tire carrier.
I am leaning towards keeping the J's and L's up front, but switching out the rears to non-L shocks and non-J springs in the rear. Anybody running a similar setup? I don't want too harsh of a ride since i won't be running a J rated load for a while to come.
I know to exented the brake lines, bump stops and drop the sways...just waiting to see exactly what is optimal for my suspension first. Thanks! :beer:
I did the same thing. If you are not prepared to make an additional investment you're kind of stuck. The J springs require additional caster correct, i.e. plates, adjustable pan hards, swap bar drops, etc. Basically everything in the Slee 4" kit
Slee - Toyota 80 Series Toyota Land Cruiser Suspension
Now if you just have the OME 850 and 863 and not the J's you'll be fine.
I have J springs, and ended up doing caster plates and swaybar drop blocks. I had some DS vibes, but they were smoothed out with the added weight of sliders. Go figure, but every truck has its own story...
Cheers and good luck!
Joel
