another no interior lights thread
Everett, Wa
Alright, I've searched both online and through the cruiser and I'm stumped. I have no dash lights, minus my right turn signal. I have a "new" headlight switch which I cleaned the contacts on. I took apart the gauge cluster and cleaned the circuit board, replaced all the lights, and checked the contacts. I've checked all the fuses and the fuse box ground.
There are a few interesting issues I'm having:
  • When I turn the dimmer all the way to the left I blow the taillight fuse
  • The left turn signal worked yesterday for a few hours, but stopped last night
  • The oil pressure gauge is not working. It has worked sine I owned the 40 but stopped last night
So I know this is a shot in the dark, but I'm looking for new places to check.
Thanks,
Irish
is there a good way of cleaning the contacts inside of the barrel connector? Could I use MAF cleaner or some spray, let it dry, and hope that works?
Need just a bit more information.
Has any of this ever worked? Why do you have a new switch? Are you sure it's the correct switch? What started this happening? Were you doing anything when all this started?
After looking at the schematic, you must have a short in the dash lighting system if you blow fuses when you turn the dimmer all the way to the right. The only reason you don't blow fuses immediately when you tun on the park lights, is because the dimmer switch is a resistor. When you turn the dimmer all the way to the right you take the resistance down so low, that enough current flows to blow the fuse.
What is on the dimmer side is the Gauge cluster lights, the heater control light and the dash pad light. Look for any Red/Black wire going to those lights that may be pinched or melted. This one may be hard to find. You might have to pull the harness and un-tape it to find the short.
Well that sounds like fun! But it gives me an idea of where to look. Thanks for the info!
I replaced the switch after the coil inside that controls resistance eroded and I found it on the floor one morning. I cannot remember if any of the lights actually worked. I had it apart for so long I'm drawing a blank. I'll take the harness apart and start following the wires.
This drawing might help. There are two RB wires coming off the headlight switch. One goes to to the headlight switch light bulb, and the other goes down the harness where it is spliced and splits into three wires. One goes to the gauge cluster, one to the heater control light, and one to the dash pad light.
Irish11 wrote:
* When I turn the dimmer all the way to the left I blow the taillight fuse
Which in my thinking is; the dimmer is hooked up between + and - and there is no load in series.
In other words.... an adjustable short.
Rudi
Alright, I tore into the harness this afternoon with no luck. I do have (check continuity with my multi meter) a connection between all my dash lights and the barrel connector pin. What I'm having trouble with is a connection between the power source and the dash lights now. I'll keep digging.
*edit* I have a light and a turn signal! Both left side lights are still out. Also I can turn the dimmer all the way to the left and not blow a fuse now. I call it progress!
This diagram is really useful. I have power to everything in the dash except the dash lights. I've pulled the switch to clean it and when testing power from RB to ground I am only getting .04v ? I would imagine that twisting the knob will vary the voltage from 0-12v, right?
One other thought is that the RB wires have been melted, but regardless I should get power coming off the back of the switch when pulled, right?
U can have a burned , melted , broken rheostat dimmer spring itself , a visual inspection as well as a electrical one is in order here
they become corroded and a coil will fracture killing the circuit function
I took apart my switch entirely and tested continuity. I discovered an interesting problem in that there is no continuity between the rheostat dimmer spring and the post which the coil attaches to. I attached it by just bending a section of the coil around to touch the post. I hooked it all up and upon turning the dimmer it blew the fuse.
Before messing with the switch the parking lights worked so I know that the problem now is with this portion of the circuit. I'm going to hunt down the wires to the dash lights, the gauge cluster, and the heater control light and work backwards from there.
In the meantime I recorded a little video of my disassembly.
I solved the blown fuse issue. It appears that the upper dash was plugged into the heater dash plug and shorting the system out.
I also replaced the cluster ligths with leds.
Unfortunately, I didn't get to test it out because I mysteriously completely lost all power.
If you had the gauge cluster out, and accidently shorted the Amp Meter studs to ground, you might want to check your fusible link out under the hood near the battery. It could now be blown. I sell replacement links if you need one.
Could also be a defective Amp Meter. You can short across the Amp Meter studs with a test lead. If you regain power then the Amp Meter is blown.
