Another LS Conversion
The 80
Year: 1997
Engine: 1FZ-FE
Trans: A442F
Grade: GXL
Factory Options: SRS, ABS
The Donor
Model: Holden SS Commodore
Year: 2004
Kilometres: 131,086
Engine: GM 5.7L LS1 w/Drive By Wire
Trans: 4L60E
Several months ago I was driving home from work and my 80 started to lose power and splutter. I pulled over the first chance I got and got, switched off the engine and pulled over to see what was wrong.
All the leads seemed to be secure, nothing visibly wrong in the engine bay and it didn't seem to hot considering it was about 40°C outside.
I started it up again and again it was spluttering away but it was hemorrhaging bright red coolant, out of the exhaust!
The head was pulled and confirmed to be warped but otherwise in excellent condition however I always found to be under powered and the trans was no doubt due to be rebuilt soon as well since it had done almost 300,000. I spent the next 6 months tossing up whether or not I should rebuild, replace with same, do a diesel or LS conversion.
After carefully weighing up the pros and cons I decided on a second hand LS1 and a brand new 4L85E. The day I made the decision I found a donor car in the salvage auctions and about two weeks later it arrived in my driveway.
I've spent the last few weeks stripping and selling off the bits I don't need and it looks like I'm actually going to make a profit even though I'm keeping the engine, ECU, BCM, TAC, all the looms etc.
Yay for free engines! :)
I've now pulled the engine and looms from the 80 and received my approval to modify from my state authority. I'm also getting it engineered on multiple tyre sizes so I'll be allowed to run 270/75 R16, 285/75 R16, 315/75 R16 or even the skinny tyres.
I found the body loom for the lights, wipers etc to be a bit excessive so that is all going and will be replaced with some custom made switching modules that communicate on a single wire and will turn on individual relays for each light, eliminating power supply issues. I will put an override switch on the back of the headlights should something go wrong with my modules and I need to see to get home. The brake-lights will remain hard wired.
I may also add a 24V alternator and add a third battery so I have the standard 12V system for the cars essential systems and 24V for lighting, my fridge etc. All up I expect to save several kg in weight just from having smaller looms.
Next up is separating out the ABS wiring from the main loom and sending it away along with the commodore loom and injected LPG loom to be combined in to one.
