I've read many previous posts about the lockers but got confused
The diffs on my 96 FZJ-80 will not lock and I see no CDL dash light when I pull the shifter into 4Lo. (I do get binding of the drivetrain though). Not sure if I've seen the CDL light since I've owned the rig, what does it look like? Should it light up when you turn on the ignition? I also hear the relay click every time I put it in 4Lo and take it back out, but only the blinking diff lock lights when I turn the locker dial. I also tried pulling the shifter lever in and out of 4Lo like 30 times with no change.
Also, the ABS light does not come on in 4Lo, but does when I first turn on the ignition.
I got underneath the rig and located the transfer indicator switch that is on the front top of the transfer directly above the transmission support on the US passenger side, or right side of rig. The wire bundles look good, nothing obviously burned or shorted.
Newb questions:
How do you disconnect the electrical connector on the transfer indicator switch without breaking it; just squeeze it and pull up?
How do you remove the switch, just unscrew it with a box wrench or ?mm deep socket?
How best to try to unstick the transfer indicator switch, spray it with something like CRC electrical parts cleaner while pushing on the detent ball (think I read that from Landtank), and how can I test it? Or, just best to replace it?
I also read in a link to Slee's tech website that you can test the circuit and lights (CDL and ABS) by shorting the connector. How do you short the connector? Where do you stick the paperclip (without burning something up)?
Thanks guys
Newb questions:
Thanks guys
