Another "locker" question
Maine
Ok guys, I've searched, and couldnt find anything to help me out. I'm new to 80's, and their e-locking system.
When I first got the rig, I went right to testing out the rear/front lockers by simply turning the dial, without being in 4lo, the indicators on the dash would just blink... so turn the dial back to unlocked position, and put in 4lo, the abs light, and center lock light would illuminate, then I could lock front rear, and the dash light would illuminate.
The other night, I went out wheeling with the guy I sold my 96 4runner to, and put it into 4lo, no light, no lock, then turned the dial for front rear, no lights blinking or anything.... tried cycling from 4hi to 4lo what seemed like 100 times, never even seeing the cdl light, or abs light flicker.
So... my question is... is there a fuse somewhere that might be blown? Maybe I fried a relay somehow? The lights, and lockers worked fine litterally days before the other night. The only thing I did that may somehow be related, is trying to figure out why my offroad lights dont work, but I dont see how that could have caused this issue. So I'm basically just wondering if there might be a simple solution, before I dig out my dmm, and start testing every damn thing in the rig. Any links to fsm or wiring diagram for my 96 e-locker system would be greatly appreciated too
T.I.A.
HA! I got it figured out, and it was directly related to trying to get my offroad lights figured out. Turns out the p.o. wired them to the 30 amp "power" fuse in the fuse block inside the rig, that blew when I hooked up my lights, which explains why I was getting no power to them :D
Replaced the fuse, and now cdl locks up great, front locks quick and easy, but the rear kept flashing... I was on tar in my driveway, so I didnt work too hard to get it locked in.
So, the moral of the story is.... check all fuses if you try to lock, and nothing illuminates.
I'm also wondering why the lockers cant be locked unless the cdl is locked... I remember my buds 4runner had to be in 4lo to lock the rear, but I did the grey wire mod (cant remember exactly, but I think I cut the grey wire, and connected it to ground) and he can now lock whenever he wants... why isnt there a similar mod for our 80's? I can think of plenty of situations where having the front, or rear locked without the center locked could be helpful...
although, Im sure someone will tell me to just arb's or something :D
It is just the way Toyota wanted to do it. It might have something to do with not wanting idiots to drive around on the pavement with them locked.
You can install an external center diff lock switch by repurposing a Toyota hazard light switch to over ride the low range switch. You can also modify the wiring to allow the CDL to be open in low range. Search
Does your buds 4runner have a center diff? Lockers would be very ineffective IMHO unless a front or rear differential is under constant power. If the front was locked and the rear was not, then one spinning rear wheel would stop the truck. With the viscous coupler that is not entirely true as there would be a percentage of torque split between front and back but that is not much different from just locking the center to begin with.
