Another Knuckle Stud Reminder!
sandcruiser
....back in the saddle again....
Pacific Grove, CA
Working on my brakes today (pesky pesky brakes this week) I was surprised to see that two of the 4 nuts on the bottom of the driver's side knuckle were finger tight (er... finger loose). The other two weren't real tight either.
I cranked 'em down with a 17mm wrench, but tomorrow after I've finished the brakes (I hope) I plan to clean the gunk off of the knuckle so that I can torque them down correctly.
Anyone know the torque setting of the top of their head? (yes, I'll search if nobody answers).
So... get out there and check your knuckle stud nuts!
Checking your nutz is always good.:rolleyes: The torque spec is 71 foot pounds, but I typically go a bit higher, like 75. It's also good to check them each time after a day offroad.
Thanks for the number. I imagine I didn't torque them down quite that far--- there is a fair bit of greazy grimy dirt on that knuckle (rebuild kit on the way). But at least they are tighter than they were and will probably survive till I get a chance to clean it up a little.
Use 2 nuts on each stud to re-torque the studs in the knuckle housing. After each stud is tight, then torque down the nuts. About 50 ft/lbs on the studs into the housing.
-B-
My wife returns from the USA today with a knuckle rebuild kit. I'll retorque the studs when I do the whole keelbasa- probably next weekend. For the 100 miles I'll be putting on it between now and then, I'm comfortable with what I've done. But good call on using the double-nut to tighten the studs. I'm assuming that the "right" thing to do is to remove them, loctite, then replace/torque.
Hijack , kinda
Is it just an nut issue or do the studs tend to come loose?
Are the " new " studs any better?
Hijackoff
ken
New studs are much better. You want them.
Hey honey, while you're in the states... pick me up a knuckle rebuild kit would ya?
LOL! Thats just funny I guess
What makes the new studs better?
We've dragged back all manner of things. This trip included a rubbermaid container with a knuckle rebuild kit and a dehumidifier. Must have looked crazy on the xray machine.
I checked four shocks and two OME add a leafs one time (with some clothes and shoes in the box as well. I've checked a full OME springs/shocks set for my 80.
The list is long and sometimes funny. Shoot, I've mail ordered stuff that I know I can get here- just that it is easier to have it delivered to her in the USA than for me to drive an hour to pick it up myself. Probably the only advantage I can think of to the fact that she has to spend 3 weeks out of the country on business trips 4 or 5 times/year.
iirc, there's an allen hex insert on the end of them
The "new" style stud is 10mm torx. You need a female socket.
-B-
in a pinch you can make a regular 9mm socket work, but it doesn't fit quite right
I had the same problem, to do the job properly, you need to thoroughly clean the knuckle threads before fitting the new studs, this is hard to do if you have not stripped down the knuckle housing, get threads as oil free as possible and liquid metal the studs back into the threads.
Torque the studs in, with 75ft lbs (new type) since I have done mine 5 years ago, had no problem since.
