My friend has a 72 with an F motor, it had a very low (barely off the guage) oil pressure reading. He changed the pressure sender, and oil (15-40 wt). I have no idea what oil was in the engine before the change.
Started her up and the oil pressure needle moved to the High mark on the factory gauge (idle). After 15 minutes of run time it stayed on the high mark. Engine was up to temp and outside air temp is above 40*.
I can think of two things,
1. The sending unit is bad
2. The oil pressure regulator is not working properly or needs to be turned down. (it is facing the right direction)
I searched but did not find the answer to this one. Only one instance where a gauge stayed on High and didn't come down until a long highway drive and engine at idle.
I am going to recommend to him to put in an autometer mechanical guage.
Just wondering what pressure does the High mark on the factory gauge actually equate to? And is this bad? ie too high?
Thanks
Jon
Thanks
Jon
) Thanks for all the timely responses.
