Another HG bites the dust...
Houston, Texas
at least I think it did. I burned a quart of oil in less than a week, sweet smell in the exhaust and the bubble test showed a rather slow but fairly steady stream. Three strikes and I'm out. So I spent about five hours on her this afternoon and didn't even complete page one of the repair process in the fsm :doh:. It was at this point I realised I'm in over my head. Since I'm about a 1/2 :banana: wrench, this is gonna take a while and a lot of questions. One of my biggest problems is the lingo and terminology of parts, (think Days of Thunder here). I don;t know what to call some of the parts when trying to explain my problems so please cut me a little slack here. Btw, I'll order the video from Doug tomorrow, but I have a couple ?'s now.
1. I can't locate the fouth bolt for the throttle body. FSM shows it to be between the two sensors or whatever they are called. I did see what looked like an allen head down in there, Is that it?
2 There is a little clip holding the wire next to the alternator, (not the
connector on the back or the plug that is unbolted) how for the love of all that is good do you get that clip to unfasten without breaking?
This should hopefully be a good learning exercise. Well thats the bs I keep telling myself anyway.
History- Truck has been extremely well cared for. 188k on the clicker. Truck has never run hot but did run warmer than normal ( RT temp guage mod was done about two years ago) for a little while over the summer till I installed a new oem radiator. Blue hub clutch installed 1.5 years ago and cutch fluid upgraded to 6k at time of rad. replacement.
Wish me luck
Buck Buchanan
2 There is a little clip holding the wire next to the alternator, (not the connector on the back or the plug that is unbolted) how for the love of all that is good do you get that clip to unfasten without breaking?
I realize you are asking about the clip. However, the wiring connectors are my nemesis. Seems they never come apart easily and every darn one of them is different. The only advice I have is to study the connector if you can see it. Study it by feel if you cannot. There is a plastic clip that you will need to depress. Don't pull on the wires if you can avoid it. Pull ONLY on the connectors. Sometimes a tiny flat-blade screwdriver helps.
As for the clip.... study it and you should be able to figure out how it works.
-B-
I've seen a lot of talk about a HG DVD that was made by one of the members on here, you may want to order that.
The throttle body has four bolts. One bolt in each corner, you need a 12mm with about 6" of extension. If you look in from the passenger side fender you will see the bottom two bolts, maybe use a flashlight to help you.
This project is very daunting. But there are some great resources available to you. HG DVD, FSM, a lot of HG rebuild threads, and a lot of Mudders that have done this project and have lived to post about it.
Check in with your local TLCA chapter, I am sure you have some great wrenchers in your area. And get CDan on speed dial, you will require his services.
x2 on Beo's method of connector extraction. Pull the wires and then you will have fun trying to figure out how to get them back in--they are all weather-proofed connections (good on Toyota).
Overall, the best thing to do is to follow the FSM to a tee. Don't deviate. It's pretty well written and explains pretty much everything that you will need to do during the operation.
Things to think about:
.5. Is this your DD? If so, you need to make some quick decisions about what you are going to do and considering your self-diagnosed 1 banana skills it might be better off having a professional do this. Get the parts from Dan and have a certified mechanic make the important wrenching calls. If it is not your DD, and you want to learn, and you enjoy wrenching, and you are willing to accept mistakes and learn from them, then continue with number 1 below. ;)
1. How far do you want to go with this operation. There are a ton of cool "while you are in there" types of things that you can do that will greatly increase the life of your engine once you are done. That said, these other operations will considerably increase the money you will be spending on doing this work. There are tons of things that you can do while you are in there...if you want to get an idea, there are many threads you can go to and search through to see what others have done while they have had their head off.
2. Is this going to be a simple R & R? Or are you going to send the head to machine shop to have some head removed, valve grind, leak test, etc. Expect to pay anywhere from $300-$800 for this work to be outsourced. Also, you will need to find a competant machine shop--preferably one that has worked on Toyota's before.
3. Parts. Obviously, I would recommend that you get your parts from Dan since you mainly need to tell him what you want and he will get the numbers for you and then pass the invoice off to me and I will go and carefully pack your valve grind set (04112-66035) and send if off to Houston for you. :D
4. Actually go in and read the FSM--go through what the FSM tells you to do. Do a practice run through your mind and realize that depending on the state of your vehicle, you are going to run into things like broken bolts, lost nuts, etc. Be patient and be willing to accept what may come while you do this. Again, it helps if you have some cruiserhead friends to help you and to encourage you to continue onward--it gets daunting.
5. Take pictures of assemblies and components. Label wires with tape, use a color coded system, or in other words, you need serious organizational skills or an exceptional memory to pull everything out and to put everything back in the right place.
6. Tools. You need a good set of tools--a good torque wrench, good sockets, good ratchet, good breaker bars, good measuring tools, fluids, greases, etc. You need a clean environment as well--or one that you can make clean as needed.
7. A good attitude. Realize that this is a serious project but that you can have fun with it too. Maybe you want to upgrade your PS system while you are doing this--this is the perfect time to maybe personalize the system by adding a new high pressure line, or by going aftermarket PS reservoir, etc. By creative, to a certain degree, because you can. Take this opportunity to get to understand your vehicle (in a rather, ahem, intimate manner) and how it operates, how A connects with B and how B influences how C operates, etc. This is the chance to see this stuff in action....you are getting into the guts of your vehicle.
Anyway, sorry to be long winded. I've been thinking about my own rebuild a lot these days and the above words are things that are coming across more often than not.
Most of all, if you need help, refer to the many threads available on MUD. Ask folks like Robbie, Rick, IdahoDoug, etc., and the many others who have done this and they will probably be more than happy to help you in any way they can.
Good luck. I assume I'll be packing your valve grind kit in the next couple of days.... :flipoff2:
-onur
Be organized with this. It's really a bunch of bolts and things that come off, then a bit of cleaning and lay down a new gasket before bolting it all up again. The advice on using baggies, notes, photos, etc will pay off huge as there are so many little things here and there.
Clarify the throttle body question a bit. It's covered in the DVD but I'll try to figure out which one you seek here in real time...
DougM
Onur- As always, a quality response. The rig is my dd but, I have use of a car till this Saturday. If it takes me longer than that, "Enterprise will pick me up":). I figure it's still cheaper to rent a car in the long run. As far as parts go, I already had most everything on hand to complete the job, from Dan ofcourse. I know my limitations as a wrench and no I don't really enjoy wrenching, I just want to gain confidence in my abilities as this is my family expo. rig. I will outsource the head work and would like to have the .10 milled off the head for some powa. Injectors will be shipped to RC for service. I will probably replace the ps lines while in there. Starter contacts, phh ectomie, new fuel filter and lots of other stuff already done so not too much "while in there" is needed.
I found the fourht bolt for the throttle body this morning. Sometimes having fresh eyes does wonders.
Doug- I'll order the DVD today around lunch time.
Thanks again for the encouragement and pm's. I think I can get through this and worst case scenario is I screw something up and have it towed to a mechanic with labeled baggies full of parts.
Buck Buchanan
One thing to keep in mind about sending the head out. Depending on how busy the shop is, it could take some time to get back the head. My head was in the shop for 10 days (including weekend) so my rig was down and out for 2 weeks. Of course I did mine on my own terms and not because of failure, so I had made arrangements for transportation.
Good luck Buck
RE: the machine shop, if there's any chance you're going to have them do a valve grind, be sure to take the head in there w/ cams/buckets/shims in place and have them adjust the valves for you before giving it back. They'll do this by tipping the valve stem to compensate for what they take off during the seat and valve grind. If you don't have them do the adjustment after the grind, you'll most assuredly be out of tolerance on your clearances, and getting all the right shims is not fast or cheap ... I know this for a fact :doh:
They'll likely charge by the hour for this part, unlike the pressure test, grind, and resurface, which are typically flat rate.
Finally, FWIW, I had never tackled anything as complex as HG, but w/ FSM, DVD, and rookie2 helping out, it was really no problem and a lot of fun. My wife, OTOH, has another name for the time/money spent ...
Buck,
I'll be there to help you as much as I can. We really ought to take your rear bumper and lift off and put on my rig, it'll make it easier to work on yours.....:flipoff2:
Jeff
X2 on what open options said, and make sure you take it to a good Machine shop. I can Pm you the one I took mine to if you want it. Most of the stuff is still fresh on my mind, so let me know if you need any help.
