Another head gasket?
Ipswich, MA, North Dakota, Phoenix
My '95 FJZ80 has 168,000 miles on it, runs perfect, but with one problem: it uses a little coolant, and the overflow resevoir smells like exhaust. I thoroughly flushed the coolant and refilled it with a 50/50 mixture, including distlled water, then discovered small bits of something black (carbon?) in the overflow tank. Cleaned that out, and now it seems ok, except what I've described above. Any ideas? I'm afraid it's the head gasket. :mad: Had the truck for 2 1/2 years with zero problems and 30,000 miles. If it's the head gasket, how much can I expect to pay for a fix? Don't have a garage out here, otherwise I'd do it myself. Thanks. :cheers:
Nodaksn3,
A few things to look for: Loss of coolant; rough idle, or rough running at low RPM; bubbles in coolant res. Also do a search for head gasket in the 80 section. Plenty of info.
I got an estimate of $1600 and decided to do it myself. Idahodoug has a dvd that is very helpful.
later,
Dan
I think the book rate is 18 hours at a dealer. I don't know the hourly rate these days but it's gotta be close to a $100/hr. It's hard project to do without a warm garage I'm afraid! I'm in the middle of doing one now.
Good luck.
And how much have you spent and how long did it take you to get the truck running Danny Boy?
-B-
-B-
Wolf, first let me tell you my laptop does not show that gray so well. Now I am seeing what you may have seen on those font colors. That said, my apologies for making your eyes hurt. Hopefully this is better for all who see it. It looks better to me.
As far as my head gasket job is concerned, the cost and time involved warped into no man's land the minute I decided to rebuild the lower end. Two semi-failed attempts by two different shops, and a new complete overhaul later, I am no longer in the (head gasket only) catagory.
My cost of parts, machine work, and powder coating would total around $1250. $250 machine; $500 parts; $500 powder coating.
That would also include a long list of parts including all the hoses, wear items, water pump, plugs, dist cap, rotor, mobile 1 oil, prestone green coolant, thermostat, head set, idler pulley, plug wires, constant torque clamps, silicone heater hoses, factory bent hoses, injector service, alternator brush pack, starter plunger and contacts, power steering pump overhaul, new power steering fluid cooler, most all bolts replaced with new factory bolts, including head and intake bolts.
My original decision to do it myself was based more on putting it back like new, much like when a car is restored by CCOT, or like outfit.
If time isn't important then I suggest DIY. That way you can be sure of replacing all of the little minute things that should be replaced. All those hoses, PHH, VSV, oil pump cover seal, crankshaft seal, EGR gaskets, etc will only add to the labor cost, on top of the orginal H.G. labor and material.
I'm cynical so I don't expect mechanics to do everything that I'd do and pay the attention that I think our engines deserve! I also don't know if the mechanic sends the head out for a valve job and such and I certainly won't take their word for it! Will they take the time to properly set the valve clearance with proper shims?
Most mechanic shops charge the customer book rate and if they get it done in shorter time, and they usually do, they make more money. It's in the mechanic's interest to get your job done ASAP which translates to more money in their pocket. I wouldn't be comfortable to have my junk worked on in that type of environment.
However, all of this is moot if you don't have the space to work and a second vehicle to drive around in the mean time!
Cheers.
