Hey folks,
Intermittently for the last few weeks, when I would step on the brakes, the pedal would be much harder than normal. I learned quickly that I could "push through" and pedal would feel normal.
Wednesday, things got a little more interesting with the pedal initially feeling normal when I would make stops but then it would get much harder as I came to a stop. By the end of the night - after 30 miles and several stops - the pedal got hard and stayed hard (that's what she said!")
I did a lot of searching and it seemed like the consensus on Mud is that I have a bad booster. Found one through NAPA. While I was there, I thought I do a new Master Cylinder so I picked up their super platinum emerald unicorn master cylinder.
Not to all, the pic on their website shows an Aisin master cylinder. I did not get an Aisin.
Replaced the booster. SEEMED like I got some improvement at first but it basically was the same in the end. I then decided it might be the master cylinder so I changed that and flushed the old fluid out replacing with Mr. T's own.
No difference so when I get in the truck and pump the pedal, nothing happens. Does not stiffen or get softer. When I turn the engine on, the pedal does not drop and the hardness feels the same.
Went and bought a vacuum gauge this morning. At idle, in park, I get right a steady 19. Put it in drive and it drops down to around 16. Inspected the manifold to booster hose and it seems fine.
Help!
Help!
