On my 02/80 FJ40 - I just completed re-assembly on my exhaust manifold rebuild and smog rebuild. Runs well (after I reconnected the PCV hose that came off).
I have a small vacuum leak which I traced back to the nut that mounts the air cleaner to the carb. This is the nut that connects on top the air cleaner to the post that comes out of the carb. It is leaking at that connection. Note I do have the ring gasket on the bottom of the air cleaner where it seals to the carb and that seems to be fine. The leak is coming from on top the air cleaner at the nut.
I checked SOR but can't see if there is supposed to be some type of gromet or fitting here to seal the connection on top the air cleaner.
Any advice would be appreciated.
And Happy Holidays to all.
AndrewT
AndrewT
