Mudders,
I've been looking at dual batt setups for quite awhile. I need something where I can park camp and run everything off my deep cycle then start up off my main in the morning. I've looked at marine switches, but you can't charge both batteries without selecting both. I've looked at isolators but you can't have everything running through one feed. I've finally found what I'm looking for, but I want to see what those with a little more experience think and if you think it will work. Here's the write up and the link and thanks allot:
The BEP 714 100A switch uses dual sensing Voltage Sensing Regulator (710-100A-DS) to control charging while also functioning as a battery selector. A welcome addition to the 701 selector switch, it ensures a fully charged reserve battery on board at all times.
When the switch is in position 1 it becomes the sensing battery for the VSR. Battery 2, which is in isolation, will be charged via the VSR when the engine is running ensuring it is always fully charged. When the switch is in battery 2 position this becomes the sensing battery and battery 1 is charged via the VSR.
BEP Marine Dual VSR Battery Selector Switch
BTW: Supposedly there is a 250A version but I can't find it.
