Another Differential Related Question
Clarksville, TN 37043
Can someone tell me if there was a particular model year when Toyota switched from a course to a fine spline on the rear pinion gear or vice versa?
I feel so stupid for not having discovered this earlier. As part of my frame off rebuild I installed a rear OEM NOS 3rd member on my 4-speed 3.7 ratio 79 FJ40 last year. I didn’t install the rear drive shaft at the time because it would have interfered with the installation of the gas tank later.
When I tried to install the drive shaft two days ago I discovered that the hole pattern on the flange on the end of the “new” differential doesn’t match the holes in the flange on my driveshaft.
I still have my original 3rd member and could take the original flange off it but before I remove the flange from new differential I was hoping the get some reassurance that the old flange will fit on the new pinion spline.
It seems that Toyota used a number different hole patterns over the years. I’ve spent time this weekend looking at website that sell parts and the only thing they seem to key on is year and model. None of them provide, cautions or even mention the hole pattern on the flanges.
Is the NOS flange round? If so turn the yoke 45 deg and drill a new set of holes... problem solved.
If you end up doing any differential rebuild work, I highly recommend a multidrill flange. It has a new sealing surface and has all the common Toyota patterns already there (LC and Minitruck). Costs you an extra $50 but simplifies your life for decades. Cruiseroutfitters is your source.
