another but different, check yer' nutz thread
North Cadillac
Towards the end of last weekend's wheelin' trip, i noticed that my right rear tire sure seemed to scrub on the fender a lot more than normal. It was extremely muddy, wet and nasty so i took a glance under the truck and all the links were there and straight. So, i just figured i was really giving her hell. :hillbilly:
Well, today i decided to crawl under the rig now that i have pressure washed all the crap out from underneath and see what new dings i got because i know i hit on some rocks.
As i looked at my lower rear control arms, i noticed that one of the bolts holding the lower arm to the axle had come out. It was dangling in there and the nut was nowhere to be found.
I really think that i'm going to use blue loctite on all bolts that hold suspension, axle and brake components in place.
so check all yer' nutz.
Insta-3-link? :lol:
All kidding aside, did the nut shear off or just back itself out?
that sucks, i just did my own front end rebuild and i have no torque wrench :(
Ryan...... i think youd want to go borrow or buy a torque wrench for that one. They are not that pricey compared to the cost of a whole front axle as im sure you realize. Plus i bet a local autozone would rent one out. Lots of parts w/ specified ft/lbs for them to be happy at. I know you dont want to dive back in there, but it would probably be best to do sooner rather than later. Or be prepared to do it all over Again. I would just want the satisfaction of knowing it was done right after spending that much money.
i have to second that. i replaced the suspension bushings in the rear upper and lower control arms about a month or so ago and after reading this post, crawled under the rig to double-check my nutz, and one of the nuts on my lower arms was loose (DS axle). it wasn't like it was about come off (i haven't wheeled since the bushing change, tho) but it was probably no tighter than ~40 ft/lbs (spec is 130). gonna put the blue glue on all of 'em tomorrow.
Also, most of these suspension nuts and/or bolts are, according to the FSM, not resueable. They should be replaced and not resued.
went to purchase new bolt/nut/washer and it was $13.33 with tax. I don't want to lose to many more of those!!
I had two trucks in my garage a while ago and they put on a lift in each. Both trucks had stuff loosening and falling off.
All the nut and head bolt sizes 22mm and larger need to be hossed up pretty good. I recommend getting down there and use your legs top tighten them up. There is no way you're going to break that hardware with standard wrenching tools.
Tourqe specs for the front leading arms and panhard are 127-130ft/lbs. That is a lot of effort
With the size of most of those bolts, you should use red Loctite. Just stay away from the green stuff, unless you never want to be able to get bolts and nuts apart again. Just my $0.02
if you're talking "red" as in 271 then that's a mistake. The only way to break that bond is with a torch. I use a MAP gas torch because propane doesn't get hot enough. Putting that much heat to the hardware might cause some problems with the bushings.
Just make them real tight and you will be fine.
IIRC using any sort of anti-seize or loctite changes the torque (wet torque)
From quick research via the intertubes, it seems that by adding any sort of lubricant (and loctite is quite slippery) you're essentially doubling the torque reading on your wrench, which means if you add loctite and torque to 130 ft/lbs, you're really torqueing to around 260 ft/lbs! :eek:
That being said if the bolts are being reused, I probably wouldn't hesitate to put some Loctite 243 (medium strength for fasteners between 1/4" and 3/4" (6 to 20 mm) diameters, and oil resistant) on the bolts. Just be sure to drop the torque approprately.
i'm not too worried about torque specs on these large bolts. I'm going for "breaker-bar tight as heck" with blue loctite.
