Another boredom thread...
Cookeville, TN
Yep - got bored over the holiday weekend and got a few small things done to the LC. Painted wheels and replaced the rear hatch struts per the advice on the thread here, simple and cheap.
Yes - that white **** in the pictures is snow, in TN!!!
Before
After
What did you use, the Duplicolor stuff?
Their wheel paint is pretty nice, I used their high temp stuff to paint my intake manifold to match the powder coated valve cover on my 40;)
looks great! looks like the dark grey "hammered" paint. if so, is the same as mine. i also have the lighter grey to use when i peal the flares off my 80. gonna fill the holes and paint the flare lines and all the existing grey with it. i cant afford line-x right now as i am not working, and playing mr mom.
I used DuPont Chromabase & clear. I had some laying around and wanted the ecthing primer on the alum. Easy enough to touch up and blend back in when I screw them up. Nothing special just saw it done on a few other rigs and liked the look.
Did you paint over the wheel weights? If so guess it wll be EZ to tell if you loose any. :cheers:
Looks great. I like the black wheels. I did my hatch struts a while back and still wonder every time I open the back why I put it off as long as I did.
I did paint weights and all but it will be an easy fix when I rip one off. Prep the area, blend in the color and clear, be good to go. I sanded with 320 and then red scotchbrite in the hard to reach places. Then one coat of the etching primer, two light coats of color and one coat of clear because I really didn't want them "bling" shiney. It's not a show paint job and was done in my driveway over the holiday weekend. I did all (4) wheels and prepped the spare in about (7) hours with my 8 and 6 year old "helping". (that means it could be done in much less time without the "help":D)
pk - I think it was your thread that I followed for the hatch struts, thanks man! Part numbers were perfect and exactly how it was detailed in your post.
Curt
Go to walmart they have a rattle can for $6 I used 3 cans on my LX450. Its a thick coat, you can get away with 2 cans. I used the light grey hammerad after the line-X dried and it looks great! just a cheap thought.:cheers:
