Another BG44K question
Afton VA
Does anyone have any experience with the pressurized BG44k engine treatment?
A local shop offers it for $129, which is less than I expected. I’m wondering if it is that much better than just dumping a $20 can in the tank.
Thanks
You can do this same service yourself for about $20-25 and an hour of time. I just did this service - throttle body, intake manifold clean, and fuel injector cleaning on my Audi wagon after reading about how to do it on a forum.
purchase the 3 can kit off Ebay for anywhere from $10 on up. 3 Steps involved:
1. hose down the throttle body with the can of cleaner - start the car and let it settle back down
2. connect into the vacuum system for the intake manifold and meter the intake manifold cleaner as your truck idles at around 2k rpm - it's best to have a friend help as you need to keep the RPM's pretty consistent and you need to make sure to slowly allow the vacuum line to suck up the fluid. it will smoke a bunch so make sure to be a well ventilated space. when it's finished sucking up the fluid - shut the rig down and let is sit for 15 mins.
3. head to a gas station - add the fuel injector cleaner can to your tank - top it off and then go for 15 to 30 min drive at hwy speed to help clear out all the muck in the intake manifold.
You'll see lots of smoke out of the tailpipe and then it will clear up.
Buy your friend a beer when you're done and you've saved about $100.
Thanks dharalson
I think I will try your method and save some $$.
However, I’m still curious. I know the garage has some sort of contraption that is hooked up to shop air to “pressurize” the cleaner through the engine.
Does anyone know how this works??
I don't know exactly what that system does, but I surmise it's similar to what you mention. However, I do know that it's also designed to meter the amount of cleaning fluid that goes into your intake manifold.
You can probably just pull the PVC valve hose and drop it into the open can with someone holding it and another person keeping the revs @ 2k or so. It would suck it up reasonably quick, so it's probably best to put a hose friendly clamp on it to limit how much is being sucked into the manifold. That's what I did on my Audi.
Results - slight increase in MPG, much quicker starts, and the knowledge that all that smoke was the result of the cleaner helping unclog all the oily carbon muck that builds up in the system.
Anything on these trucks to help the engine run a bit more efficient is a good thing.
BTW - you can also do this without buying the BG kit - grab a can of throttle body cleaner, a can of Seafoam, and a good fuel injector cleaner like Chevron, Redline, or Lucas type of stuff.
It will do the same thing, but I do know that the BG fluids are of superior quality.
