another axle question
Lake Tahoe
I have a 71 fj40 and want to upgrade to discs with fine splines. I want to run 35-37" tires. I have been reading the tech links alot and understand the benefits of the mini-axle swap but I can get a complete 77 axle for about the same price as a mini axle. I know the pinion gears in the 77 axle are still coarse but plan on changing my gears to 4.88 and doing a front locker sometime in the future. Is there any reason (other than availability issues with the birf) that I shouldn't just use the 77 axle (after rebuild of course) instead of doing a mini axle conversion. I also plan to do longfields and know they are not as common but.......with the 77 axle I wouldn't have to uprade my steering right away. Will my current system handle the front discs or will I have to upgrade that too.
Or......should I just spend the extra money and do the mini axle swap?
77 has a smaller pattern steering Arm (Weaker)
and im guessing its got warn hubs for the 1/2" longer birfields (weaker)
id just do the mini swap! i started with the 76 stuff(same as 77) and now have the minitruck stuff..
I should note that the minitruck Brakes are Solid rotors, Whereas the 76-78 Cruiser stuff is vented rotors.. so thats the only pluss side of the cruiser stuff
Buy yourself some Minitruck IFS Calipers and FJ60 Rotors and these will swap onto the minitruck stuff!
WELCOME TO MUD -- My motto is do it right the first time..
1979 and later Land Cruiser and Mini truck knuckles have the larger bolt pattern which will accomidate more hysteer options...and the Front Range knuckle stud upgrade...
You are going Longs, so get the Aisin lockouts and chromo drive gear for them...
While you are building your disc front axle, get the 1988-1992 V6 Pickup and 4Runner front calipers that have four equal sized pistons in the caliper...
Good luck!
-Steve
