Another alternator thread...sort of long
Southern CA
Ok, i spent Saturday on the board and under the hood (and dash) doing some wiring work... 69 fj40
i replaced the white wire from starter to + post of ammeter; placed unswitched fuse block here (mistake, but read on) for headlights
engine started and all electrical components work; and ammeter showed + charge
turn signals caused normal ammeter bouce, but headlights did not make needle move.
tested a couple of times, then at one point engine did not start. did more searchs on Mud, go back to cruiser, now it starts, but ammeter no longer shows + charge
then i replaced the white with blue wire from alt to - post of ammeter; engine did not start :doh: ; forgot to replace the reb with black wire to ignition; did that, engine starts, all electrical components work fine, but ammeter stays center except with turn signals, but only on negative side, ammeter still shows no charge
back on Mud, :idea: unswitched fuse block is off of wire between alt. and ammeter, not battery and ammeter; fixed that; engine starts, all electrical components work fine, but ammeter STILL stays center except with turn signals, but only on negative side, ammeter still shows no charge
did i fry something? i read a lot about the voltage regulator yesterday, is it possible that i fried that during one of my engine start tests?
btw there was no fusible link in the equation before I started this (it came along in later models i discovered here in Mud), but I do have a 50amp fuse between battery and ammeter (will be changing this to fusible link in future)
thanks all!
that would help... stock F engine, stock alt.
The only thing that should be connected to the + post of the amp meter is the battery (the battery lug of the starter motor is OK on older cruisers). If you connect the headlights on the battery side of the amp meter, the meter will read "charging" when the headlights are on, even though it may not be charging. It kind of defeats the purpose of the meter.
Other than that, it isn't clear that anything else is wrong. If you are wondering why the amp meter doesn't deflect to the right, the possibilities are that the battery is already fully charged, the alternator isn't putting out enough power or there is a bad connection between the meter and the battery.
Pinhead,
it was your post in another thread that helped me get the wiring right...
so, i have white wire from battery (actually battery lug on starter) to + post of ammeter; white/blue wire from alt. to - post on ammeter with a d-block in between for lights and turn signals.
my question is: could i have possibly fried something by having lights hooked up between battery and ammeter and that's why it's not charging?
and, from the way i understand other posts i've read, if engine is running at driving speed (not idle) and lights are on (wired correctly) the ammeter should not show negative, right?
when engine is revved, the headlights no longer get brighter as they used to (tells me that there may be something wrong with alt)
i have replaced the stock wires (white and wb with heavier guage wires) maybe the lights are as bright as they can be now with new wires and a fully charged battery.
the battery is a fairly new (under a year and rarely used) optima yellow top that i just put on as main battery.
and i double-checked connections from meter and starter and they are tight and clean.
[edit] when i get home tonight [/edit] i think i'll leave the lights on for about 20 min and then start it and see if it charges. if no sign from meter, i guess i'll have the alt cheked out. good idea or no?
thanks again for the help
badkarma said:
I have white wire from battery (actually battery lug on starter) to + post of ammeter; white/blue wire from alt. to - post on ammeter with a d-block in between for lights and turn signals.
I don't know what a d-block is or what it is inbetween, so I don't know whether this is good or bad.
Question: No.
There are easier ways to test the alternator output, but that will work. Why not just measure the voltage with it running? It will discharge your battery faster is you pull the coil wire and crank the engine for 20 sec.
thanks,
i'll do the coil discharge.
d-block= distribution block - (ie. one wire in and 4 out) used often in car audio applications
here's a diagram of how i wired everything:
pin_head,
i'm going to try some of the tests you suggested in this post tonight and see what i come up with...
found problem...
orig fuse holder requires much cleaning (or replacement) bad contact on one of the fuses... not sure which wires yet...
thanks for help!
Try this. With the engine off, turn your headlights on for 5 minutes. Start the engine. Your ammeter should deflect into the positive for a short time in order to replace the power you used to run the headlights while the battery was not being charged. If it still does not show charging, try hooking up an external Ammeter,better yet a DC amp clamp, on your alternator output wire to see if it is actually charging.
thanks bruce...
i think i found the problem last night: bad contact on one of the fuses. a little wiggling and charging worked
i'm going to clean it real good and see how it holds up.
bryan
