- Thread starter
- #21
This is an update to the original post.
The first thing I did was change the fan clutch and all three drive belts. That seemed to have helped a little. Then I did a coolant flush and that helped a little more. But I still had warm air blow after about 20 minutes with the A/C on. When I turned off the A/C for a few minutes, it would start working again. I checked the low pressure with the gauge and it read slightly above 45 psi. I think that's slightly too high. Anyway, I decided to check the A/C drive belt again and it seemed fine. Since I didn't want to start changing everything out, I figure it wouldn't hurt to tighten it a little more. So, after tightening it, the A/C seems to work now. It was on for more than 45 minutes and no warm air. I'm going to test it more over the weekend.
