I have the same rattle. I tried to tighten the 10mm screw that appears to hold it tight. I didn't even turn it 1/8th of a turn & it snapped the bolt in 2. I guess PO had already tightened it super tight. Any long term cures for this annoying rattle?
Got some rattle on the hanger upstream from the cats. I guess I need to replace the rubber, though the exhaust is so haggard I'm tempted just to do the whole system.Check the exhaust system hangers, push up on the pipes (cold of course) while looking at the hangers before and after the muffler. The rubber can split
in half allowing the system to rattle/vibrate but the pipes don't fall down due to the interlocking L shapes of the brackets.
This is the way. My truck is damned near silent now. Thank you.If the rubber "cushions" are the original, IME, they all will be deteriorated. In the 95-97 FZJ80 and LX450 models the first two are easy to get to,
the rearmost cushion nearest to the resonator is more difficult, IIRC the right rear bumper corner has to come off to get to that one.
All three cushions (for these models) are the same part, you'll may also need new nuts (4 for each cushion).
Previous discussion with photos:
Been discussed in the past and just recently so thought I'd post this up for those that haven't seen it yet.
My 97 model FZJ80 recently started getting a new vibration for example while idling in drive, foot on brake, more apparent when the engine idled up with the AC compressor coming on or just increasing the rpms with the accelerator pedal. Also it became more apparent on acceleration from a stop. This vibration/rumble got progressively worse over the course of a month or so to become aggravating enough I decided to get down under the vehicle check things out.
When I looked, shook...
- Kernal
- Forum: 80-Series Tech
