Amnesic memory seats
Some Toyota models require the seat to be "initialized." I don't recall the 100 being one of them, but it's worth a shot. Slide the seat all the way forward , seat back all the way forward. Then go all the way back with the seat bottom (with one push). Then All the way back with the seat back. Then try setting seat memory.
If doesn't work, I'd check fuse and wiring. Could be a bad seat memory switch assembly. Mine sets fine when battery is disconnected
This worked perfectly!! Thanks so much, I was tearing my hair out!
This is amazing--finally got mine working as well!! Should be integrated into a sticky or FAQ.
Hmmmmm.....no worky for me. My seat memory is suddenly not working (can't set it and it doesn't 'ding' as before) also the auto retract of the steering wheel is not working (perhaps tied to the seat memory). I can move the steering wheel manually with the toggle.
This worked for me. I unplugged my driver's seat and the memory functions would no longer register when I pushed the button. I did the re-calibration method mentioned above and all is working again. 👍
