Ok I have read all the links in the FAQ, but I still at a loss at how these adapt up. I have gear # 36212-60030, bearing#6306-32A and the seal. I oredered all these at the same time, same supplier. My 4spd trany has no step down on the output shaft, (like the 3spd did) with a 16 spline count.
I have 2 gears inside the Tcase, the one that falls on the floor when you pull the Tcase off the trany,
and the one thats on the input side, bearing attached. I get where the parts I have accualy go, the bearing in the back, under the steel PTO cover, and the gear replaces the 'fall out' gear.
But what about the gear closest to the trany, with the 10 orignal spline count? how does this work when I try to throw them all together?? Its not going to engauge being a difrent diameter right?? And wheredoes this damn seal go?
The Tcase is out of a 72, with manual shift levers, not vacume shift. I had planned on making a twin stick setup for it after I was done.
