aluminum rad!
Terrace, BC
what do you guys think about these any experience? got the chance to grab one for a around 250canuck bucks is it worth it (any difference)???
I just put a nice one in my 88 mini truck, and its nice. The one I got is a lot larger on the x and y axis and it keeps the truck super cool. I haven't even gotten around to putting the fan shroud back on and I never get above factory temp. Definitely not necessary, but still nice to have.
The guys who build copper radiators claim that aluminum cools 10% better. The guys who build aluminum radiators claim they cool 40% better. Probably best to split the difference???
I would stick with the stock replacement. I bought one from an Autozone. A bit bigger but doesnt cool any better than the stock one which lasted 185k miles.
I suppose if you do a lot of wheeling then it might a different story. Not sure though.
Same experience here. I have AL rads in both my FJ40 and my mini truck, no shrouds on either. No temp issues here, even in summer. :grinpimp:
Must be due to design. Copper has a much higher heat transfer rate than AL.
gotta be the design. copper is much better at many things than a lot of alloys or metals.
i have only found the aftermarket crap radiators around here that have have plastic tanks. i am not down with that
gotta go OEM
dont know how much 250 maple dollars are but in usd 150 is what i see those crap ones goin for. id rather spend 100 and get my OE radiator rebuilt buy a specialty shop
Aluminum does a great job, but if you don't have any problems cooling with a stock radiator, or don't have any big modifications on the engine, you won't see any advantage.
I have a relatively small (19"x22"x (1) 1" core) aluminum radiator cooling my Supra swap and it does a great job if I'm not pulling a trailer through hill country. I just got this beauty to replace it though so I can pull those long grades with 2 tons on the rear bumper and no overheating
Ron Davis double pass, 2 core, 24.5"x16"x2.75" - - found it at a flea market for $25! (2 tubes repaired)
rad
thanks for the info guys. i tow a small trailer and have a camperette for the back of the truck so i was thinking a bigger rad might be better in the long run.
matt
