Aluminium Radiator - eBay
We've had a few threads on aluminium radiators over the years but no one I can think has actually bought one.
They do make some sense,lighter,cheaper,better cooling claims
I had this post here a few years back,didnt go far.One of the replies forecasted massive corrosion and basically the radiator becoming a battery,but nearly all vehicles are running aluminium radiators these days including new Landcruisers.
https://forum.ih8mud.com/diesel-tec...ta-diesels.html?highlight=aluminium+radiators
You might want to wade through this lot also
IH8MUD Forum - Search Results
Thanks for that roscoFJ73
I've ordered it .. so if it blows up, falls apart or is plain crap .. I'll let you all know :)
Ill be keen to know if it runs cooler,I think some of them claimed 15% or was it 30%?
My rad is good but I think I will give the aluminium one a go when this needs replacing.
order it anyway, use it as a spare or orimary
with parts on these trucks hard to find, it would make sense to install it in front of the existing radiator and use it as the primary or backup. I have only seen one photo of a cruser with two radiators and said..why? well, it makes alot of sense for a vehicle that is at times, hard to get parts for. If your radiator suddenly fails, you already have a spare installed. Swap out the radiator position, add water and go. No waiting for a tow truck, no need to sit in a hotel waiting for the shipment of a radiator. There is lot of room, with trimming of the radiator fan shroud to install a second radiator.
I know this is an older thread but looking for an affordable radiator option for my BJ42...how have the cheap aluminum radiators been? Did people use the expensive coolant?
one guy in Australia with a bj-73 I think it was had bought one and 3 out of the 4 mounts have broken during one of his trips into the bush.
That's me.
The radiator was 6 months old. The seller never came through with the warranty (it had a 1 year year warranty). $250 down the drain so don't buy one from cooling_auto ... It failed on an extremely corrugated road 150kms from the nearest town, luckily for me the core wasn't punctured so I tied it up with wire and limped back. I could have had new brackets welded on but the core also had a pin hole leak so it wasn't worth fixing, I think it had the leak from new.
It cooled fantastically (never got above thermostat temp) and I'd consider running another with gusseted mounts and/or an added pair of mounts. They're certainly good value for money and it cooled better than the 4 core copper brass that replaced it despite the eBay one being about 15mm thinner.
