I replaced my alternator and it isn’t charging, the old one wasn’t charging as well, what should I check? I have looked at my fuse all are good, any help will be nice
1973 fj40
1973 fj40
Alright thank youstand by for some pics
i have your prescribed remody up in a moment
I replaced that and still not charging, where should I look beyond that?ok ,
look closly at the fire wall under the brake master , see that little black box ?
i am going to assume since you have a 73 , your bl;ack box has a 3 wire little black connector plug too on its pigtail ?
that's this live part here below
its called a Voltage Regulator
any time you replace your alternator due to unit faluure , its TEXT book VIAS Toyota's College level T-TEN program to go ahead and
replace the much lower pocket change at the tome regulator too in tandem
please click this LINK for more info and TECH too :
Genuine NipponDenso / DENSO OEM Toyota Voltage Regulator 27700-60080 9/72-9/77 FJ40 , FJ55 - VintageTEqParts.com
Genuine NipponDenso / DENSO OEM Toyota Voltage Regulator 27700-60080 9/72-9/77 FJ40 FJ45 FJ55 Comes with Genuine YAZAKI harness...vintageteqparts.com
p[l
And I know the alternator plug is disconnectedHere some pictures of the VR and alternator
Oh there another plug you can see in the picture what connects to the VR, that just the plug that came with the alternatorYour white/blue alternator output wire is a short circuit waiting to happen. Has all that stripped insulation exposing copper wires indicative of the cable pulling out of the crimp connect?
Also, the wires in your new connector at the alternator don't match the colors of the wires entering the connector at the regulator. Have you double checked to make certain they match the schematic provided by @Steamer ?
Can’t *Oh there another plug you can see in the picture what connects to the VR, that just the plug that came with the alternator
I will tomorrow when I get off shift,Can you take a picture of the connectors at the voltage regulator showing bot connectors mated and the wires fanned out to see what the wire color codes are? Can you also do the same thing for the connector from the alternator to the voltage regulator? Fix the WL wire and make certain that you disconnect the battery before working on it.
Yes I did have it all connectedJust so we aren't assuming anything... did you plug in the voltage regulator when you tested the new alternator?
Will these pictures work? And I know I need to fix the white wire,Just so we aren't assuming anything... did you plug in the voltage regulator when you tested the new alternator?
