Looking for a working Alternator for my 1962 FJ40. Can't seem to find one that looks like the one I pulled off mine. Stamping only says 12068.
@ToyotaMatt
forum.ih8mud.com
Pulled it off to swap to the new one. It's a two belted pulley that also drives my P/S pump.where is your Pulley ?
Yep. All the other ones I've seen had the bolt holes straight across from each other or offset in the wrong direction.
Searched there, but never had much luck posting wanted items.1. What does the back look like?
2. Why wouldn’t you just post in the classifieds?
3. does it look like this?
For Sale - SoCal-first generation alternator-JDM Firetruck
Reorganizing some of the used parts I keep at home (private stash) I found this rare bird that came on an F135 firetruck engine I imported around 1993. The metal tag has the lowest 600xx designation I have seen on an alternator. Also, as the pictures show, the alternator came with post...forum.ih8mud.com
Is that for sale?
Is that for sale?
Do you have a current part number on this? I need to source a rectifier for my old one.
This has a eight diode layout, but only six are used.i have some NOS genuine NipponDenso Japan rectifiers , but i need a visual on your burnt up one
i am not a rectifier expert sight unseen , but i can indeed mach up by eye for sure
- oh , BTW : please hit the REPLY tab icon in my post here your alternator when you have a question , it will then alert my inbox here on MUD
thanks ..........
matt
Yep, actually mine still had one, but wasn't working so it along with a half dozen other parts got traded at SOR years ago for other parts that I needed. I should of held onto it though.You do know your 1962 FJ40 came from the factory with a generator? I never actually purchased a pre 64 that still had a original Toyota generator. Few with alternators and GM generators. Like my old starters found original generators separately.
i need the center points of A , B , C , and D in millimeters Please
this is the only way i know of to make this a 1 time Rodeo minus any guess work or speculation either ...
bring on the TECH !
