I'm just finishing up a frameoff buildup and I need some help figuring out why the alternator isn't working. Here are two pictures with all the wires labeled. I have checked a couple wiring diagrams, both of which differ a little from each other, plus I'm working with an EZ-Wire harness......and I don't know wiring very well.....at all........ So here's how it goes: the main wire on the alt. "B" post is hot, and the alternator excitor wire on the voltage regulator is hot when the key is on. When the key is turned on, the volt. reg. flips the internal switch. I don't know if that means it's working 100% or not, but I don't know how else to test it. So basically that's it - when I hook up the voltmeter to the battery it reads about 11.5, and when I start the engine, it doesnt change at all. Am I missing a ground wire somewhere? Where would it go if I am? I was assuming the alt. was grounded by the mounting bolts. The battery is a fairly new deep cycle. I'm also unsure if this alternator is in fact a stock unit - can anyone confirm that? The engine is a 1972. There is also a connector labeled "N" where the "F" and "E" wires plug in, but there is no wire inside the plug for that connection.
Thanks for any help you can provide. I guess I can always go pick up an internally regulated alt. if I can't figure it out.
