alternator stator
The West
hey . I recently was polishing the metal housing on my alternator, when i stupidly decided to open the housing. then , as I was trying to put it back togehter , the stator wire that goes to the brushes broke. Can I replace this. I really don't want to go get another alternator. I like th estock one just fine, because my wiring harness has a special plug that plugs right into the alternator and i don't want an aftermarket one that wont fit. Plus, i don't have the cash. Can anyone help?
Haven't worked on Nippondenso alternators but Delco brushes come with wires on them. I'll bet you can just replace your brushes.
(The stator usually isn't connected directly to the brushes.) :)
ps - I'm just guessing about Cruiser alternators being Nippondenso. Probably got that part wrong! t
thanx . maybe i had my terminology messed up. the bunches of wires in the alternator have a single wire that connects to something. that broke. wondering the cheapest way to fix it.
Which alternator? What year and type?
On later alternators, the three common ends of the "Y" type stator windings (the stationary ring shaped, wire wound unit) and joined together and connected to a wire that is used to run the charge light (or idiot light) that connects to the "L" or "N" terminal (depending on which alternator) on the alternator. These are lacquer coated wires usually connected with a crimped metal clip. If this is what you are talking about, I would use a crimp connector and solder it.
Pictures would help.
ok . Ill get pics tomorrow afternoon. See, I have a 1970 fj40 with a 1977 2f in it. So it might be the older alternator. It sure looks a hole lot like the older ones. See i dont know all the terminology but you really think I can crimp it back together? By the way this stuff was painted red over before.
