DC Power Engineering makes a 270 amp for $600:
Our XP series high-output alternators are the ultimate upgrade when you need the absolute biggest and most sophisticated high output alternator on the planet. All of our XP series alternators are designed for one purpose, brute force idle output. When you need the most extreme idle output with...
www.dcpowerinc.com
I have one of their 180 amp alternators in my 470 and have been happy with it. It's probably overkill for my needs, but I was proactively replacing the alternator anyway and figured it would be good to have a slightly bigger one for winching use and running LED lights. They have higher idle amperage than other aftermarket alternators, and I always felt the OEM alternator was weak in that regard (lights would dim at idle sometimes).
When I replaced the alternator I also performed the "big 3" battery cable upgrade (with 1/0 cables that I cut and crimped) and upgraded to SDHQ billet battery terminals. The OEM hot wire from the alternator to the battery is only around 10 ga or and is unfused, so I think it's plausible that a big alternator coupled with a big accessory draw could melt that cable and possibly start an electrical fire. The 1/0 cable should safely handle 250+ amps. Lastly the SDHQ terminals are much better than the OEM terminals (and safer electrically) for mounting accessory cable lugs.
Also it's nice to see another eastern Missouri member on here!
