Alternator Locking Bolt Replacement Needed
Halifax, Nova Scotia, CANADA
My alternator locking bolt and adjusting bolt came loose and fell off the alternator slider bar on my KZ-TE engine while driving. The bolts are easy to find, but I haven't been able to source the square "locking nut" that holds the two bolts at 90 degrees to each other.
The alternator bolt is an 8mm and the adjusting bolt is a 6mm.
Does anyone know where I can find a replacement locking nut?
Thanks in advance for any help or advice.
Wrecking yard
Check any old toyota, parts are most likely the same.
Found an alternator tensioning "slider" from the local Toyota parts department, part #16385-17010. It is a good permanent fix, but not perfect as the original tensioning bolt is a 6mm not an 8mm on my engine.
Now to guage the belt tension...
