Alternator issue?
Mesa, AZ
So driving yesterday 91 3FE after about 30 minutes of driving voltage started fluctuating really bad then temp gauge started to to rise rapidly pulled off at the next exit then everything went back to normal popped the hood fan spinning no problem no other signs of overheating and no issues after slowing down speed. Did a search and most people say to check grounds and get alternator tested. Will this need a bench test since it's a random issue or siomething else to check. The temp gauge there me off though. Video of voltage fluctuation in the link.
https://photos.app.goo.gl/HLpZCOH6f5kOXiqW2
The "temp gauge fluctuation" COULD be induced by a bad ground or the voltage fluctuation.
Go to a FLAPS and have your alternator tested for free (on the vehicle).
Check belt condition and tightness.
Get a mechanics stethoscope and listen to the bearings on the alternator to confirm if it sounds OK.
A common sight is a customer comes in with nice tight fan belts however, they are very worn and running at the bottom of the pulley. All it takes to get the belts to slip is some additional load, fan VC kicking in, AC being switched on and the belts lose traction, water pump slows, charge drops ect.
Plug at rear of alternator also a known culprit.
Regards
Dave
Thanks guys belts are brand new experienced a drop in voltage a couple of weeks ago which led to belt replacement the old ones were pretty rough. I will recheck grounds and get it tested on the vehicle and see what I get thanks for the help!
Recheck belt tension whilst there, and confirm they were a Toyota matched pair, if not you may find one belt has more tension than the other.
Regards
Dave
The 3fe only has 1alternator belt
Stopped by Oreilly today did a battery and alternator test I think the guy was an idiot though and everything test fine even though it was spiking in the parking lot during the test. I am going to start digging through grounds tomorrow as well as the connector at the alternator and associated wiring fusible links are brand new as well.
I think the auto store alternator tests are a really simple voltage check. I was asking about them a couple of days ago since I'd like to get an output graph for 130- and 150-amp alternators.
You might check if there are any automotive electrical rebuild shops in your area. They'll be way more competent.
Thats what I was thinking as well I will still dig into the wiring and grounds to make sure.
