- Joined
- Jun 11, 2009
- Threads
- 2
- Messages
- 3
I want to fit a rev counter to my Series 80 Landcruiser. After a long battle, I found a VDO rev counter that goes up to 6000 rpm max - ideal for my 80's 4.2 litre diesel engine. However, when I wanted to fit it, the auto electrician told me the alternator on my truck does not have the necessary electrical points on the back cover of the alternator to connect the rev counter wires to. He suggested I get a different backplate for the alternator I have, or I get a new alternator with the proper electrical connections. He will then install the new alternator and or backplate and connect the rev counter for me.
New alternators are quite expensive - ±$400, and labour is ridiculously expensive; it could easily cost me another $600 to get it installed.
Do you have any recommendation regarding the alternators - type, parts numbers and so on - and how difficult will it be to install the alternator myself?
My Series 80 does not have a fitted tacho, that's why I went to the trouble (and trouble it was) to find a aftermarket tacho (VDO makes a 6ooo rpm max one). I have also just been informed by someone else that I should use the fuel pump connectors for the tacho. I will go and have a look if that may be an easier way out.
