I am having trouble determining if my alternator is charging the battery... just swapped a 2F into a 72 and am trying to get this 40 somewhat dependable. Anyway, tested voltage at "B" terminal 24V?? I have read the previous issues using the search but how do I know that the alternator is connected to the battery? PO has chopped the wires...battery has negative ground, positive to starter,and one other fused wire running to fuse block...should there be something else? Could not find a wire schematic in the haynes manual I have...looks as if it may have been removed...help would be greatly appreciated...
