Blue Chip said:Well, the installwent perfectly! I had to adjust the bracket a little to fit the alternator - but very simple and straight forward. The belt went on the instide pully - closest to the alternator BTW. Once I figured out which wire went to where - it was less than 30 minutes. Charging at almost 13.5 voths at idle - with a charge of 14.7 at 2500 rpm's. Headlights don't dim with the turn signal and the AC on any more...
Thanks for all of the help on this!!
Glad to hear the install went well, but i am curious why yours is riding on the inner pulley and pimps and riding on the outer one? Is there a way to adjust it to ride on the outer one? I ask because i am looking for a way to mount my york on the passenger side of the motor and it appears that if i duplicate pimps alt setup, i should be home free! I already got the brackets ready to go, looking for a pulley to drive it now, and just adding a dual pulley is a no go because it would hit the fan. For some reason, pimps alts sits a good amount closer to the firewall so that it is using that outer pulley! that would be perfect for what i need
if you are running the belt on the closest pully to the alt, how close is the outside pulley from the fan? mine is almost touching as is and it is the single one
any chance on some pics from the side? or insight as to why one MG alt is sitting so much further back on the same engine?
thanks a lot
kevin
