I read through an older thread on a guys volt gauge pulsing and one comment on there said a new alternator will do that and fluctuate voltage. he said that you need to run it for a good 10 hours so the brushes wear enough to form to the armature. it makes sense but is there any truth to this?
not too long ago my voltage regulator went out and I bought a Toyota reman and now I'm getting weird goings on...
first off, I have the blue seas auto charge relay and switch to go with it. theres an led wired into it to show if its isolated on start, low voltage lockout (9.5vdc), or charging. i also used #2 welding cable for the entire system accept the start cable is oem.
now when I'm sitting at a light and have the ac on, and my lcp fan on i can see my voltage drop and the batteries isolate because of discharge.
could it be that the new alternator brushes need to seat properly?
