If you Put your left hand on the tcase shifter, right hand on the dash, shift all your weight to the left hand, the shifter will move a little. With continued jerking cussing and violence it might move into N if your lucky it will go to low. Once your in it works fine, and its not much trouble to switch back to N or H. Any thoughts? CDL doesn't work btw. There isn't any physical obstruction on the lever that's noticeable from the underside. Thanks guys.
