All warning lights
Nairobi
Website
www.bushwings.org
Howdy!
A new gremlin on my HDJ-81: All the engine warning lights flicker. The gauges are rock steady, but the charge light, the A/T light, the oil light and temp light, along with the T-Belt and turbo lights flicker, particularly over a bump. they have, a couple times, come on and stayed on for a few minutes, but again all gauges show normal.
I read in some other threads this might be an indication of alternator or charge system failures, but the symptoms aren't quite the same.
Any thoughts?
Thanks!
J
Same thing happened to me, it was in fact the alternator.
Warning lights
Sounds like it is time to get the alternator serviced with new brushes and bearings.
Or at least clean the mud out of it.
$10 says it is the alternator..... well tha or the truck is about to blow up :grinpimp:
X4 or whatever, it's probably the alternator. Typical signs on a US spec truck are the Charge, AT/P and Brake lights coming on at the same time.
The "particularly over a bump" part makes me suggest that you check battery connections and ground connections first. If these are OK then the problem is likely the alternator.
-B-
check your alternator belt... my alternator pulley broke off in my accord and the alternator belt was still there but was moving only around the pin....
ooops.. I misread the original email... yeah like WXM states below, that happened to me on my LX and it was the starter... eventually the plunger stuck and had to get a new starter...
Not sure about the T-Belt and Turbo lights flicker part, but in my case, the charge light, the A/T light, the oil light and temp light stayed on due to the bad starter contacts, replacing the contacts and plunger seems to fix it.
check the plug and wiring to the alternator first. I had this same problem and the gray (or black can't remember) plug on the rear of the alternator wasn't fully snapped into place.
