Alingment Problem
Went to get my 92 alinged today at a local shop. They tried multiple times to get it right, but could not figure out why it pulled to the right bad. Finally they switch the tires around and determined that it is due to what he said waas radial pull because now it pulls to the left bad. The work sheet only showed a small camber adjustment. I know enough that the adjustent wouldn't cause the pull it makes. Well they are saying that its the tires fault and I need to take them back were I baught if I have a warranty. The tires are BFGs 33x12.5x15 AT. Just would like some feed back to see what you guys think. I did inspect the suspension and linkeages and everything looked good before I went, also I measured the distance from the front tires and they both came in at 52" 7/16 from each other. What else can I do just to make sure?
Radial pull is a real thing. I had some Dunlops on an Acura Integra that caused radial pull over and over. Would put a new tire on that corner, problem would go away. Next time I would rotate and balance, and the problem would show up again with a different tire. It was a nightmare. Switched to Michelins and the problem was gone, forever.
Don't know how susceptable the 80-series is to that issue, but that Acura was highly susceptable to it.
Not saying that is your issue. But it is a possibility.
Before I go and argue the warranty on the tires, should I set the pressure to what the max is written on the tire (32 psi) or should I set to the factory specs.
Use factory specs.
But if it's pulling badly due to tires, the pressure shouldn't change things. As long as the pressures are equal for the tires on that axle (ie front versus rear).
